Originally Posted By: Fordiesel69
Be carefull on gen. It can simply evaporate the oil due to high governor loading. On a tractor for example, the gov opens up when you turn the mower on and when you hit high grass, the rest of the time it is at 1/4-1/2 position.
On a gen, once the governor opens, it must stay there to maintain 60Hz. This will cause the engine to use oil.
5w-30 / 10w-30 is not a good choice. A robust 15w-40, 5w-40 syn diesel oil would be better. Or if you must a 10w-30 diesel oil like rotella.
a generator is going to fluxuate as well, ie running a refigerator, the butterfly/govenor is going to open up when it kicks on (much like turning on a mower deck mowing) and when it kicks off, the load will be much less. Also, assuming this is a lose built briggs L head, I cant see how using synthetic of any weight would be a good idea? Assuming this question is about a generator being used today in the USA (not even Nov yet), the best bet would be sae 30, imho
But you will be using other things, so total load will probably be more than a mower for example. At least mine is.
Good point, I wasnt considering much other than a fridge, as I havent been w/o power for much more than 1 day in a long time. Back to oil, if the OP decides to use syn (I certainly wouldnt) in an older briggs be sure you check it, and check it often regardless of weight.
