D DreamerGT Joined Jul 9, 2009 Messages 384 Location austin,tx Oct 28, 2012 #1 I have no idea on where to start looking to fix this. Also the code will go off and on at random times. Thanks
C carwreck Joined Apr 4, 2009 Messages 464 Location CT Oct 28, 2012 #2 "Boost control solenoid" per the GM codes from grandprixforums.net GM error codes _______________________- 1987 Toronado 1999 Olds GLS
D DreamerGT Thread starter Joined Jul 9, 2009 Messages 384 Location austin,tx Oct 28, 2012 #3 Well I guess that answers why I'm not making full boost when the light is on. Ok thanks Last edited: Oct 28, 2012
D dan_erickson Joined Aug 5, 2010 Messages 1,072 Location Crown Point, IN Oct 28, 2012 #4 move the boost bypass valve by hand to make sure it is not stuck, It had happened to me more then once.
D DreamerGT Thread starter Joined Jul 9, 2009 Messages 384 Location austin,tx Oct 28, 2012 #5 Will do thanks a lot
