Originally Posted By: JOD
It looks quite clean, though that's what happen when you own it since new and know there were no 30K OCI's with 2 qts. in the sump!
That is true. Thinking back I may have used quite a few Honda filters with the Clean 5000 as well.
I'm curious, how were the valves @ 100K? I'm suspicious of going that long, but I also know the engines have changed over the years. Intake valves tight?
They were actually all slightly above (loose) the tolerance spec (pretty much evenly so) and I set them to the spec using a go/no-go gauge.
