Originally Posted By: GC4lunch
The OEM plug in the Mazda6 V6's Ford Duratec engine is a double platinum fine wire, and the owner's manual says to replace it at 75,000 miles with a Motorcraft AGSF 22FCSM, a part number no longer recognized in the Motorcraft catalogue. We have the original plugs in ours at 85,000 miles, and plan to replace the plugs at our next oil/filter change at about 90,000 miles. Our choices are the NGK ITR5F13 (NGK 6044), an iridium/platinum plug with a 0.6 mm iridium center electrode, and if we install those, they should last until our car hits 200,000 miles or until I am pushing up daisies, whichever comes first; or we can install the Denso IT16 (Denso 5325) with a 0.4 mm iridium center electrode, which . . . probably would need to be replaced . . . in the 110,000 mile range on our car's odometer.
There was no discernible wear on the gap of my 6's Motorcraft plugs at 60,000.
No difference when I switched to single platinum NGK G-power.
No measurable gap erosion with 30,000 on the G-powers. I'm going to leave them in for 60,000 this time.
Since I posted that statement that you quoted above about two choices (among many options for replacements for the OEM Motorcrafts), I have become acquainted with another iridium plug option, the Bosch Iridium OE 9657. A lot of bad stuff (quite possibly justified) has been written about Bosch spark plugs, and a rather
bizarre meme has been spun out that Bosch plugs should be used only in European cars, NGKs and Densos should be used in Asian cars, and Champions, Autolites, or Motorcrafts in American cars.
I'm going to call b.s. on the meme. Our Mazda was assembled in Michigan by UAW labor, and its engine is a Ford Duratec that has never crossed an ocean, but the logo on the hood is the logo of an Asian brand. I would have no compunction putting an NGK plug from Asia, a Bosch plug from Europe, or a Motorcraft plug from America in it.
As for others' bad experiences with Bosch spark plugs, I take that history more seriously; but analytical review indicates that the bad experiences mostly relate to the subset of Bosch plugs that are of multi-contact design. Bosch seems to have fallen in love with multi-contact designs a few years back, and there are a lot of bad stories about the Platinum +2 and Platinum +4 plugs in particular. I would have some trepidation about adopting Bosch's latest multi-contact plug, the Iridium Fusion. But the Bosch Iridium OE plug is not a multi-contact design, and looks very much like a copy of the NGK Laser Iridium plug, except that the noble metal fused to the ground electrode of the NGK is platinum, whereas the noble metal fused to the ground electrode of the Bosch is an iridium-platinum alloy. And the retail price of each Bosch Iridium OE plug generally is a couple of dollars lower than the price of an NGK Laser Iridium plug.
The Bosch Iridium OE is a relative newcomer to the market compared to the NGK Laser Iridium, which has been around for a few years, and I would like to see more user reviews and tests of the Bosch than exist now, but I take comfort in
this straightforward statement from NGK's own website:
Quote:
A common misconception is that changing spark plugs will result in a large power increase. In most cases, removing even seriously worn out spark plugs will only result in very modest power gains, typically about 1-2% of total engine output. This could be even less for computer-controlled vehicles, primarily because most newer vehicles have more powerful ignition systems and the vehicle's computer can make adjustments so that vehicle operation seems smoother and more seamless.
Many people think that simply supplying more spark to the firing tip can and will combust more fuel. What they don't understand is that most newer cars' engines are so efficient that they are already burning all of the available fuel. Simply adding more spark voltage can't burn more fuel because there is no more fuel to burn.
When a stock or near-stock engine is given a fresh set of spark plugs, peak efficiency is restored. The power gains that come from this restored state of tune are usually minimal. Any company that tells you that their spark plug will provide significant gains in power in a stock or near-stock engine is making blanket statements that may not be supportable.
I didn't put NGKs in my Mazda because it's Japanese. I put NGKs in my Mazda because I like NGK. I put NGKs in my Chrysler too. Put them in my Normal, Illinois made Mitsubishi and my old '96 Mustang too.
I did read somewhere that the MZI variant of the Ford Duratec was assembled in Hiroshima. Like most intraweb "facts" I take that with a grain of salt. I do know that the first variants of the Ford 3.7 Cyclone V6 were made in Hiroshima.
The only time I had problems with a fancy plug is AC Rapidfires. The AC sales rep came by the shop, gave us some swag (mostly pens and stuff.)and a free set of Rapidfires so we would be encouraged to push his line of wares. My 1.3l Suzuki Swift started and idled well but for some reason ran like there was a rag stuck in the airbox. Just no power. (not like the SOHC G13 had any power to begin with)
I cannot understand why. It was obviously allowing a spark to jump the gap and igniting the fuel air mixture but it could not be driven at any reasonable speed. Regular set of copper core NGKs went back in and it was fine.
It ran fine on Splitfires. I got a free watch from them.
I wonder if sales reps still visit retail shops with Swag? I liked my Castrol "Members Only" style jacket
