What do degrease a chain with?
Along the same lines as the diesel fuel, wouldn't gasoline work too?
I will look at that ZEP degreaser as well. For $12/gallon it should go a long way and might be the best thing to use if I want to use it indoors.
http://www.homedepot.com/Bath-Cleaning-S...51#.UGCSyyJbqzc
BTW, I tried using some diesel (really home heating oil) over the weekend to degrease something (not a bicycle chain) and it worked great.
Back when my chain maintenance caring level was high, I used to remove, soak in varsol, wash with water, soak in oil and then drip "dry" for a few hrs. Now I use the on-bike chain cleaner .. so far have been using simple green but only because that's all I had handy.
But diesel fuel - is there a concern with benzene inhalation/absorption?
While diesel has aromatics, id guess that gasoline would be more filled with benzene. They tend to be bigger aromatic molecules in diesel.
But did it flash off?
with what? Another lighter solvent?
I just bought some finish line multi degreaser... I think they dont recommend using citrus on everything for some reason. havent looked much into it.
That ZEP Citrus Degreaser is powerful stuff. I'd cut with water on a chain unless it's really dirty or something.
I think I ruined one of those Vetta chain cleaners by using mineral spirits. The plastic case warped & didn't fit together properly any more. Safer to use water-borne degreasers. I've used a couple different things similar to SimpleGreen but still looking for something more effective. I'll have to try some of the things suggested here.
Use brake cleaner if I have a can that's almost empty. Otherwise, I'll take a mineral spirit soaked rag and run it on the chain. If it's really grimy, I will take the chain off and put it in a jar full of whatever petroleum solvent (spirits, kerosene, seafoam, etc.) I have left over and shake.
