Originally Posted By: RamFan
Ok so let me see if I got this correct.
You turn the ignition which activates the starter. The starter extends the bendix drive into the flywheel and turns the flywheel until combustion occurs. Once this combustion occurs the bendix retracts. So with the bendix retracted is the piston down force causing momentum for the upswing portion of the crankshaft or is the crankshaft actually pushing the piston upward? I guess, is the crankshaft a free floating shaft that spins at a rate that the pistons dictate or do the pistons go up and down at a rate dictated by what the crankshaft allows?
In a single cyl lawnmower, momentum keeps the rotation going until combustion occurs every other rotation. With multiple cylinders like in a car engine, a combination of momentum and other cylinders firing keep the crank rotating.
