Interesting, especially since they list an "abnormal" number, which is a useful recommendation. What test method do they use for the contamination analysis? If you can also get the make and model number of the test equipment, it would help my database info as well.
If these result came from a true optical particle count, then the oil is exceedingly clean. Of the results I have, however, the DELO is the cleanest of the bunch!
