I was just reading another post where some chap mentioned that a semi synthetic engine oil was recommended and this is one subject that I find interesting, as how do you define a semi synthetic oil, apart from the fact it is a dino oil with extra synthetic additives.
If anyone asks me what type of oil they should use, then apart from suggesting they look in their manufacturers handbook or ask the dealer, it often becomes a case of listing a full synthetic oil or a basic dino oil.
To further confuse matters the Brits and the Americans don't use the same oil groups as the Germans, so you have to then figure out if you want to include HC (Hydrocrack) oils in the fully synthetic category or do what the Germans do and refer to them as synthetic technology oils. As I live in Germany I only consider an oil as fully synthetic if it meets the more exacting German standards and it is often worth check the German oil sites to find out if an oil you are buying is a genuine synthoil or not.
Unfortuntately there are some new cheap HC synthetic engine oil brands starting to appear in the UK and US under the fully synthetic label that have verious dubious base stocks and add packs, so it is definitely worth check on which group a new oil is in, although often it is just a case of you get what you pay for with new engine oils.
At the end of the day I think the Germans are very correct in the way they define oil groups and the terms part synthetic and HC synthetic were dreamt up by oil company sales teams trying to change the image of their cheap dino oils for a more high tech man made one.
