Here is my very first UOA. I am checking with Blackstone on where the sodium levels could be from. The only thing I can think of is I added a bottle of Redline SI-1 within 500 miles of taking the sample. I added it to 1/4 tank of gas then ran until the refill indicator came up before adding more gas. Other than that, who knows? They did wonder if the sodium could be from previous oil. Prior to this interval of Amsoil OE, I have only had my truck serviced at Toyota so whatever dino oil (assuming 5W20) they had in bulk is what has been in this truck. I never paid extra for their synthetic and always changed at 5,000 miles.
Currently, I am running GC 0W30 and I plan to run a 2nd consecutive GC batch after this as I have it on my shelf. After that, I may try to push the Amsoil OE to 7,000 miles and do another UOA.
Code:
DAVID: No fuel was found in this sample, but we did find an unusual amount of sodium. Perhaps you just
switched to Amsoil from another oil that used sodium as an additive. That would mean this sodium is
residual additive, and in that form it's completely harmless. The other common source for sodium is coolant,
but you don't have any of the other signs here (like coolant or high wear). In fact, your wear looks great
compared averages, which are based on 6,000 miles on the oil. The TBN was fine at 2.9 since a reading of
1.0 is low. Try going up to 7,500 miles next time.
Code:
ELEMENTS IN PARTS PER MILLION MI/HR on Oil 4,834
MI/HR on Unit 42,424
Sample Date 08/23/12
ALUMINUM 2 2 3
CHROMIUM 0 0 0
IRON 4 4 10
COPPER 3 3 5
LEAD 1 1 1
TIN 2 2 1
MOLYBDENUM 64 64 151
NICKEL 0 0 0
MANGANESE 0 0 0
SILVER 0 0 0
TITANIUM 5 5 1
POTASSIUM 0 0 2
BORON 81 81 48
SILICON 17 17 15
SODIUM 150 150 42
CALCIUM 2063 2063 2198
MAGNESIUM 10 10 138
PHOSPHORUS 687 687 672
ZINC 781 781 802
BARIUM 0 0 0
Values
Should Be*
PROPERTIES
SUS Viscosity @ 210°F 52.5 46-59
cSt Viscosity @ 100°C 8.04 6.0-10.2
Flashpoint in °F 400 >385
Fuel %
Antifreeze % ? 0.0
Water % 0.0
Insolubles % 0.2
TBN 2.9 >1.0
Code:
Code:
ALUMINUM 2 2 3
CHROMIUM 0 0 0
IRON 4 4 10
COPPER 3 3 5
LEAD 1 1 1
TIN 2 2 1
NICKEL 0 0 0
MANGANESE 0 0 0
SILVER 0 0 0
TITANIUM 5 5 1
POTASSIUM 0 0 2
BORON 81 81 48
SILICON 17 17 15
SODIUM 150 150 42
MAGNESIUM 10 10 138
ZINC 781 781 802
BARIUM 0 0 0
Values
Should Be*
PROPERTIES
Fuel %
Antifreeze % ? 0.0
Water % 0.0
Insolubles % 0.2
TBN 2.9 >1.0
