Amsoil OE 5w20, 4083 Miles, Dodge Caliber
Ohio
I ran the factory fill for 1250 miles, then switched to Amsoil's 5w20, just the OE "cheaper" line of synthetic. Amsoil oil filter was used.
I expected the silicone to be high, as it's a brand new motor (bought the car new). However I'm not sure why they flagged base number?
Image version here.
Code:
Iron 12
Chromium 0
Nickel 0
Aluminum 4
Copper 11
Lead 0
Tin 3
Cadmium 0
Silver 0
Vanadium 0
Silicon 50 *
Sodium 3
Potassium 0
Titanium 0
Molybdenum 117
Antimony 0
Manganese 1
Lithium 0
Boron 94
Magnesium 8
Calcium 1991
Barium 1
Phosphorous 686
Zinc 769
Fuel Dilution
Soot
Viscosity 100C 8.2
Base Number 3.53 *
Oxidation 10
Nitration 8
I read on the forum that Blackstone have a lower limit of 1 on TBN.
What engine is this fitted with?
We get the Caliber in UK but most have a Merc sourced diesel engine.
Correct, Blackstone says a TBN of 1.0 is too low. In reality, TBN is too low when it equals TAN, I believe -- aka the amount of base left is just enough to neutralize the acid in the oil. Below this point, the oil becomes acidic.
I would guess its flagged as yellow just because it is getting lower. The point at which it becomes red may still be 1.0 for this company, too.
blackstone says 1 is too low and others say you're not supposed to go lower than 1/3rd of the original tbn of the oil.
Originally Posted By: Bill in Utah
This UOA is NOT blackstone.
Who did it?
Oil Analyzers Inc. Its the kit I got from my Amsoil guy.
Actually, for a nearly brand-new engine, that's pretty impressive for wear metals.
As for the TBN, I don't believe it's an issue. No TAN makes it hard to understand why they flagged it.
Looks great! @dnewton3. Don't some labs flag TBN when it has been reduced to less than half of starting TBN? Maybe this is one of those labs?
This is a nice UOA. The Tbn is perfectly fine, no need to worry. 1.0 is low when dealing with B/S labs.
This is not Blackstone labs. (Open the link). It's OA from Amsoil.
Regardless, TBN of 3.5 seems high for anyone to condemn, w/o knowing the TAN (which they didn't report, even if they did test it).
As for a lab condemning a lube with only 1/2 the TBN remaining, I'm not aware of such, but that doesn't mean it's not out there ... Seems like a huge waste if that were the case.
