Looking for suggestions on trans gear lube and final drive lube for my 2013 Subaru BRZ. Factory calls for a GL3 lube in the trans. Hoping to change soon to something that might improve the shifting feel.
Redline MT90, Amsoil MTL and Pennzoil synchromesh are a few I'm considering.
Also for the final drive...factory calls for GL5 so again any suggestions. Looking at M1 gear lube or Royal Purple Max Gear.
Car has limited slip but it is a Torsen type (gear) so no limited slip additive needed.
Both the trans and final drive call for 75W-90 weight.
Thanks...
Thanks...
