Originally Posted By: BillyTheKid
Fact - I have seen people in my racing take A LOT of power out of their tune and go faster. Did the oil do that too? Should we think that way?
What you have seen or experienced is at the noise level if that compares to what companies like Shell, Motul, Mobil, etc. are doing for a living. I preferred hard evidence like the record book instead of just hearsay like you and others are doing, the term is bench racing. Rotella does not even advertised their oil as motorcycle oil and Shell is actually making several types of racing oils that you don't even know about. The problem here is as I have stated before you are not a credible source compares to the majors. You can run other auto oils not just Rotella in your bike and it will be fine too, a lot of people do it. You even agreed with me that Rotella is cheap and that is it. You have no proof that Rotella is better than Motul 300V or even just as good. Feel free to start a new thread on how to save money and use the same oil that you use in your combine and your semi in your lawn mower and your bike.
Here is a real fact, professional racers will sacrifice an engine to win a race and it is called 2WT race oil. Only amateur wannabe racers that can't afford to race or to win so they end up trying to protect their engines. The funny thing is they will always try to defend the inferior products they are running in their vehicles. Why is Rotella not in the winner circle of any professionally sanctioned races?
