Originally Posted By: Jim Allen
Thank you for accolades but since I got the filter for free, I can't take credit for taking the bullet... but I would have.
Dome end- threaded end? No difference. I have been interviewing filter engineers and "washing" just doesn't happen to any important degree during a bypass event. First off, the dirty side of the media is under pressure, so the particles on the surface of the media are being pressed there in the direction of flow. Secondly, they are embedded into the media. With depth media, like full synthetic, with some loft and varying density, a lot of the dirt is deep inside... it ain't gonna wash off. Possibly more likely on a pure cellulose media, which is more a surface loaded media.
During a bypass, dirt that's flowing in the oil that bypasses will be all the "dirt" that bypasses. If the oil is fairly clean to start with (a high efficiency oil filter keeps the oil pretty clean anyway) it's a non issue 99.9999 % of the time. Add to that, my interviews are yielding the fact that bypass events are not common outside of cold starts. I have been trying to get averages for these folks, but there really aren't any because there are so many variables. I will say that if you are one of those "thicker is better" guys, you are more likely to be bypassing more often than if using the spec'ed oil viscosity.
Not enough media mgm13? It's synthetic so it's depth media.. meaning it doesn't have to carry everything on the surface, as with cellulose. I have a FL820s and a P1, so I will shoot the three media together. They are similar size. I still can't find the capacity info but I'll get it. It has at least a 26g capacity, as the Xtended Guard did. That's big.
I'll repeat... "plastic" is a pretty generic term. Unless you know the material specs, you don't really know anything about it. How it "looks" is immaterial. After a while, I'll beat on this one a little and see how it holds up. If you are intellectually honest, comments on looks don't really cut it.
I have one ready to go. The plan is to use it twice (2X7k OCI total of 14k). Take it off, let it drain, put it back. Anything wrong with that?
