I have a husqvarna 125L. It now has become to not idle too well. Smokey and it does not want to get past the rough idle. I have been using stihl 1gal mix with a little bit of StarTron. My guess is that I poured the last bottom amount of mixed gas in the weedeater's tank and then this happens. I reckon that since the star tron does not have a great measuring system like STABIL it is kinda difficult to guess the amount needed without over use of the expensive product.
Could a loose spark plug wire cause my weedeater to run bad? Last time I changed the plug the socket couldn't get on the plug just right and when I wiggled the boot too much it sorda popped off into my hand.
Now back to the startron. If they just steal a little patent or just make a bottle similar to stabil I think I would think they would see more.
Other than that idea I think it would be good just to use the marine formula of Stabil since the ethanol treatment is already in there and in the cool measurable bottle.
