I tend to be of a similar opinion to turbo picture newton, that there is not very much difference in how a fully synthetic oil and a good dino oil will perform unless you start pushing the oil change limits, BUT if you use a fully synthetic (Including HC synthetics) I think the chances of either sludge or varnish build up in the long term causing a problem for the turbo in particular are almost nil.
I am looking around to see if there is a better oil available in Germany than the LM Synthoil 5/40 and although I think Mobil 1 and Castrol Edge are just as good, does it help much in terms of cold start and multiple stop starts, to choose an oil with some Moly in it? Liqui Moly seem to have decided on using other anti wear additives in most of their oils.
Informed opinions would be good to read.
