Like the subject says, let's talk about Varilock differentials as equipped in Jeep WJ's:
First axles:
First axles:
- Is pump behavior, friction material, etc supposed to be the same for both D30 (front) and D44A (rear) devices?
And viscisity:- How does viscosity affect behavior? Will a thicker oil promote engagement earlier because it doesn't bleed out of the reliefs?
And lubricant properties:- How are the clutches affected by dino vs. synthetic?
- Is the use of more or less Friction Modifier than prescribed detrimental to clutch lifetime or is it strictly a behavior/road manners correction?
- My understanding is the transfer case's power split device works in the same way as the differentials', with a gerotor pump and a stack of clutches. The transfer case is (reportedly) picky about lubricant - requiring only Mopar 05016796AA or Mobil #424 fluid. I know this is a much thinner viscosity than 75W140 but would there be some other magic fluid in Mobil's (or anyone's) commercial lubricants catalog that can offer improved behavior in Varilock differentials?
