Originally Posted By: Trav
Quote:
Modern gasoline engines should do OK with any oil from 0W-20 to 20W-50 and with any certification
Under the operating conditions these engines are running under this is false.
Anything 20w is not recommended in engines running under these conditions.
With modern synthetics 15w40 and 20w50 are for the most part obsolete weights in gasoline engines (granted there maybe some racing apps or older air cooled).
Quote:
One thing that may be is that when you changed the oil type, the antiwear films on your rings/cylinders got modified. That may sometimes cause temporary problems until new films form
That's really stretching it thin.
If you read his original post, his ASX owner's manual is recommending anything between 0W-20 and 20W-50 for his climate. (Of course, you shouldn't run 20W-50 in subfreezing temperatures.) Also, Toyota for example recommends anything between 0W-20 and 20W-50 for most of its cars sold in Europe. Toyota recommends only 0W-20 for exactly the same cars sold in US.
My guess, explained in my post above, is that he doesn't have a problem at all.
