I'm going to fix a blown head gasket on a 1992 Buick Century 2.5l Tech4 engine, and I cannot find any info on where the plug to drain the block is located. I'd like to drain it as much as possible before I pull the head so I don't get any coolant in the cylinders. Anyone able to help?
Also, I've done one of these on an older engine (1985 or 86) and if anyone has any other helpful hints I'd really appreciate them. I'm not sure if there are any differences between 1985 and 1992 engines. Thanks.
