Hello,
I am changing out the rear hydraulic and transmission fluid in these tractors. The spec from the OEM say it requires a M2C134D. This would be the fluid from New Holland. However i can save $75 on 15 gallons if i get the premium grade from Napa. The exact name is Napa Premium Heavy-Duty Tractor Hydraulic and Transmission Fluid. It even list wet breaks as one of its uses. On the back it mentions that it meets or exceeds the following with M2C134D (OEM spec) being one of those numbers. So my question is, is this basically the same stuff? Is it just as good? If so i would like to save the money but if not i would rather buy the correct stuff as i plan to keep these tractors for a very long time.
Thanks in advance for your replies.
