2000 Nissan Maxima
I just had slave cylinder and hoses replaced. Now the clutch pedal is really stiff and engages at the top of the travel and there is no free play left at all. The clutch pedal rests about inch higher than the brake pedal and all the engagement seems to be happening in the top inch of the pedal travel. I am not sure what could have gone wrong. Master was not touched during this repair but might have ran out of all the fluid during the swapping of slave cylinder and hoses. It was bled using two person method. The pedal is not soggy at all but rather lot stiffer than it was before. The problem is that engagement point is very high.
Any idea as to what could be the culprit? I am taking back to the mechanic on Monday. He suggested I drive for a while to see if it self-adjusts but I do not see how that would work.
I searched and did not find any topic with zero free play. On the contrary, there are bunch of people who were complaining about too much free play. There are also contradiction opinions on whether the master cylinder rod should be adjusted or not.
Please help!
Please help!
