Originally Posted By: m37charlie
Mobil 1 0W40 is an excellent choice, better than Rotella T6 IMHO. It has a higher TBN to fight acids placed in the oil by the (evil) EGR system, and is the usual best choice for pre DPF European small diesels.
It is an example of an oil that works well for both gasoline engines and small diesels.
Charlie
I've got an evil EGR, but it doesn't dump acid as far as I have heard of or seen in a UOA. DPF's sometimes cause some fuel contamination, but a high detergent content oil won't help offset fuel contamination.
Try reading some UOA comparisons of Rotella vs M1 0/40 and look at the wear metals in particular for a diesel, as the classic Delvacs and Rotellas are real good in many diesels.
I'm in the EU and not so many diesel folks use M1 0/40, they prefer Castrol Edge (Or Magnetec) and Liqui Moly oils. M1 is a distant third just ahead of Shell in private sales terms.
