Today, I received the replacement slave cylinder in the mail for my Civic.
The replacement comes with the sliding pin(?) dis-assembled and I'm curious as to the type of lube to use and I need to know the correct method of getting it ready to be installed on the vehicle.
I'm aware perhaps a dab of anti-siece on the tip that contacts the clutch fork is sometimes helpful, but what about the pin itself? I don't know whether or not I should even bother removing the rubber boot to lube inside or lube the pin and insert it carefully while it is still attached to the cylinder itself. Any tips on assembly lube I can buy at an auto parts store for this? I've never done this before, and didn't know this particular aftermarket would come this way.
For those interested, it is an EXEDY SC646 and they do make quality parts for Japanese made/origin apps.
