Originally Posted By: Gabe
Originally Posted By: buster
. Higher viscosity for long endurance racing due to fuel dilution issues.
What is causing the fuel dilution issues?? Why wouldn't the high engine temperature burn it off??
That could be. I really don't know. I read an article by Motul a few years back that said higher viscosity 50 grades are used in endurance racing because of fuel dilutions.
Right, in endurance racing fuel dilution is a problem and must be compensated for.
BTW, the M1 0W-50 is not an especially heavy oil with a HTHSV of 4.1cP and it's 189 VI. Not much heavier than M1 0W-40 (HTHSV 3.8cP, VI 185).
It's interesting to see these high powered engines using high viscosity index oils. Mobil's 50 grades have become much lighter over the years. HT/HS is down. A lot of it may have to due with engine design.
Corvette's LeMans racing engines aren't the feral beasts they used to be. Since the factory Corvette effort went from 7-liter to 5.5-liter engines with air restrictors, the power is way down. And the current race engines use direct fuel injection. Maybe they're concerned about fuel dilution because of this.
Originally Posted By: mechanicx
I wonder why they don't use 15W50 as it seems that would be more fuel dilution sheering stable and 0W isn't needed.
Because it has much more detergents, and MUCH lower ZDDP & moly levels than the Racing 0W-50 (which suprisingly also has a VERY high TBN, I guess to combat those dilution issues??
I did not know they were DI, thanks for that info!!
If the FIA did not restrict the air inlets down to the size of a durned quarter, even the 5.5s would be making BIG power.
(On a side note; I wonder if the factory/street C7s are going to have the rumored 5.5L displacement?)
