Here's a few pictures of a Quaker State QS3387A filter taken off a 2005 Chevrolet Impala with the 3.8 V6. Filter was run for 3000 miles with Mobil Super 5000 (oil changed early due to an error in my records, found after the oil change!).
As you can see, the filter media has several small tears. My best guess is that the media was folded down by the seam in the factory before the installation, and the oil pressure pushed it a little farther down, causing the rips you see. Not really pleased. I don't think it hurt the engine any that I'll notice, but still.
Thoughts?
Next picture shows the tear - the two pleats on either side of the seam are torn at the top where they attach. The pleat on the left was also torn at the bottom, although this isn't captured in the picture.
A closer picture of the tear.
And again.
Thoughts?
And again.
