Originally Posted By: HTSS_TR
Originally Posted By: Arctic388
1996 Tahoe bought at 211K miles. been using Amsoil and pl24011 and PF52 filters at 229922 miles now.
www.youtube.com/arctic388/videos for videos of cut open oil filters and oil change mileages.
On the oil change after using Amsoil engine flush i used Pennzoil Ultra and with 1600 miles changed and filter was full of carbon. Thinking I might continue to use Pennzoil Ultra until filters start looking better then switch back to Amsoil.
I want to know what is the best oil to use to clean out sludge.
I would use Amsoil engine flush at reduce dosage 1/2 oz engine flush per quart of oil but drive the car for about 100 miles before changing oil. Do several 1k OCI's with any dino oil with engine flush added at 900 miles.
I used Lubegard engine flush at the dosage above in my LS400 2-3 years ago, it did very good in cleaning and didn't cause any harm to the engine.
Originally Posted By: Pablo
I cannot advise you to drive the car with Amsoil engine flush. I know the fellows are recommending a much lighter dose and driving, but still - I'm not saying it will harm anything, but it's not really been tested.
I'm late to the party. Here goes:
I see Pablo's point and I was also at first opposed to HTSS_TR's suggestion in the past.
However, if done with extreme caution to the dosing ratio and checking the oil filter at short intervals/having an oil pressure gauge if possible as well, I believe using either of these 'non-solvent' containing flushes at a couple ounces for short intervals with filter changes would be an interesting experiment.
Yet, the part of me fully going through with it would have to have the cautions such as a pressure gauge and keeping up with miles on filter would be important "decision makers."
