Originally Posted By: sprintman
I sure wouldn't put 5W30 in my BMW. Needs HTHS 3.5 at least. Do either of the oils mentioned have a HTHS of 3.5?
BMW 5W-30 will have HTHS somewhere between 3.5 and 3.6 and, if to judge by 0W-40 VOA, it may have a decent additive package. The only deficiency from purists' point of view it is not 100% synthetic. However, nowaydays it's nearly impossible to find a true 100% synthetic oil from big manufacturers on the shelves. I don't know why people are still convinced that 0W-X oils are 100% PAO or a blend of PAO and Esters. In better case it will be a blend of Gr.III and PAO or PAO and Gr.III.
I would also point out that for some BMW engines (mostly "N" type) it is allowed/recommended to use BMW Quality Longlife - 01 FE 0W-30 which has HTHS = 3.0. Interesting that on the back label it's mentionned that this oil contains MoDTC. Analogues are Castrol SLX LL 01 FE, Castrol SLX Professional Fuel Saver BMW LL01-FE and Agip 7007.
