Mr.Hagy here is your answer.
Frank
Member
Member # 34
posted May 24, 2003 02:35 PM
Hello Mystic, If you dial up auto-rx.com and click on "Application Link" you will see we are now standardizing on 750 miles, be it synthetic or dino in order to not cause confusion. Synthetic base oil is not why 750 miles, rather it's the complex additive package oil packagers put in this synthetic base stock. It takes Auto-Rx chemistry 750 miles to start cleaning metal where synthetic oil is being used. Sludge is another problem; we have seen no benefit in using synthetic oil for sludge removal and so we recommend dino oil when starting the cleansing process in sludged up engines. Complex additive packages in synthetic oil add to the sludge problem, therefore the dino oil is recommended for cleansing after which customer can use any oil of his choice.
Have a great Memorial Day
Posts: 219 | From: Ormond Beach Fl | Registered: May 2002 | IP: Logged |
Mystic
Member
Member # 1109
posted May 24, 2003 03:02 PM
