Castrol Magnatec
Castrol Magnatec’s Intelligent Molecules cling like a magnet to your engine to provide an extra layer of protection from the moment you turn the key.
At the start of your journey
Up to 75% of engine wear occurs while your engine warms up. But Castrol Magnatec’s Intelligent Molecules cling to your engine, even when it is off, always protecting and dramatically reducing* engine wear during this critical period.
During your journey
Castrol Magnatec’s Intelligent Molecules continue to cling to your engine after your engine warms up. Castrol Magnatec helps maintain top engine performance by protecting your engine in all driving conditions and at all temperatures.
After your journey
All engine oils will drain to the bottom of your sump when your engine is off but Castrol Magnatec’s Intelligent Molecules keep clinging to critical parts of your engine ready to protect when you start your next journey.
In the mean time
Even if you haven’t been using Castrol Magnatec, it’s worth making the change. Castrol Magnatec’s Intelligent Molecules start working for you the day you change your oil. They cling and bond to engine surfaces, significantly reducing further engine wear and damage to already worn parts
Castrol Edge FST
Does the Edge have intelligent molecules that cling before, during and after the journey, or are they superior and stronger molecules slightly retarded though and unable to cling
What is the difference between the Magnatec and Edge FST oils other than advertising and some Titanium additive.
During your journey
After your journey
In the mean time
Castrol Edge FST
