When I change my oil, I pour a little gasoline in an old coffee can to soak the oil filler cap, the drain plug, and the PCV valve. While the last bottle of oil is draining into the engine, I shake the immersed PCV valve back and forth a few seconds, remove it and replace it on the valve cover. I've never had any trouble with any car I've done that on, and never had to replace the OEM valve. The gas? I fashion a crude filter out of a paper towel folded twice with one side opened forming a closed corner and placed it in a funnel. (a little trick I learned in high school chemistry lab) I just pour the gas back into the lawnmower gas can through the funnel with its makeshift filter. What little dirt goes into the lawnmower gas tank, eventually gets filtered by the lawnmower's inline filter and what little oil goes into the mower engine I figure works as an upper cylinder lubricant. No extra expenses on commercial cleaners and nothing gets wasted except me after I finish and pop a brewski or two.
