Post your latest oil change
yesterday did the Jag (2 posts up)
Today did the Jeep Grand Cherokee 3.7L
Out: Amsoil OE 5w30
In: Amsoil OE 5w30
PureOne filter
Edit: Last changed oil in jeep on 4/30. Ran 4k miles in that time mostly pulling trailer.
Friday night
BMW E34 535i/5 speed M30 engine
Out: Rotella T (2800 miles)
In: Supertech 5w-30 Synthetic
Filter: Mahle
Marked gas mileage improvement around town and no oil pressure light problems; the Supertech should serve well over the next 5000-7500 miles.
2008 Tundra 5.7L
Out: Toyota synthetic blend 5W20 (made by Mobil?) w/ Toyota filter
In: Amsoil OE 0W20 w/ Toyota TRD filter
ran the old oil about 3500 miles and plan to run the Amsoil OE for 5000 and do a UOA.
2007 Fusion V6: 5qts QSUD 5w20 and 1qt Mobil Clean 5000 5w20 and FL820s
1996 Corolla 1.6L: 3qts Meijer High Mileage 5w30 and Purolator L14477
Originally Posted By: chevrofreak
2002 Subaru Outback L.L. Bean H6 3.0
Installed Mobil 1 M1-104 oil filter and used 1 quart of Mobil 1 10W-30 Extended Performance, 1 quart Mobil 1 10W-30, 1 quart Quaker State Torque Power 5W-30, 1 quart Super Tech 5W-30 synthetic, 1 quart Valvoline Synpower 5W-30 synthetic, and 1 quart Motorcraft 5W-20 synthetic blend.
I had leftovers to get rid of. I just added the 4oz Auto RX maintenance dose a couple days ago (1100ish miles on oil) because I didn't have any Auto RX on hand at the time of the change.
You should do a UOA on that...
Hyundai Santa Fe... 80,227 miles.
Took the blasted Dorman EZ Drain plug off the drain pan (a piece of garbage that never sealed and kept leaking) because it was making a mess in my land lord's driveway;
replaced the old 14612 with a new 14612;
dumped the 1k old oil back into the sump after replacing the plug and filter, added 1.5 qts of Pennzoil High Mileage. Majority of it is still Mobil Super 5000...aw heck, I actually don't know...I think I mixed some other oils in there too when topping off after it leaked out the bottom. I'm guessing what's in there now is a mixture of 45% Mobil Super 5000, 10% Quaker State Ultimate Durability, 15% Valvoline Next Gen, and 30% new Pennzoil High Mileage. Anyways,
PZ High Mileage 10w30 added, new filter put on.
2006 Chev Avalanche
Out - Syntec 5w30
In - 5 litres of PYB and one litre of Nemco 0w30
Fram cheapo filter to replace the even cheaper Motomaster filter.
2008 Mazda 6i 2.3
57341 miles
kendall 5w20 full synthetic out UOA to come
casite filter
in with PP 5w20... UOA to come after... let the fight begin...
1988 Alfa Romeo 33(1.7L), 139000 kms
interval: 2000 kms (recent rebuild and needing a thinner weight for winter start ups)
Out: Motul 300v 20w/60 w/ Mann W719/14 oil filter.
In: Castrol TWS 10w/60 w/ Mann W719/14 oil filter. (16th June)
Mother's 2004 Honda Accord V6. 120k on the engine.
OUT: P1 oil filter, 5w30 Syntec - 7,500 OCI
IN: D+ oil filter, 5w20 QSUD
Doing first UOA on it, if it looks good will run this OCI a little further.
1994 Geo Tracker - 1.6L
Out - Formula Shell 10w30 & Pennzoil filter
7500km on oil - 10 months
In - Formula Shell 10w30 & Pennzoil filter
Valve cover, Timing belt, water pump, camshaft and crankshaft seals, and distributor housing seal replaced 200km prior to change.
