Chattzx, what was your oil pressure like? When I got my Z32TT I know pressure was lower than stock. Come to find out the majority of VG30DETT's had dented oil pans. Even the smallest ding near the pickup will starve the engine, since the clearance is almost less than a .25inch. I replaced the pan on mine, and pressure went back up.
Im going up to BIR this weekend for MAP's proving grounds, along with Powercruise @ BIR next month, and will be running either Rotella T6 or something heavier.
I did make a 3000 mile trip from MN to SC and back with a dented oil pan, however I had some Lubromoly MOS2 in there, which could have helped, since I held steady oil pressure @ ~30PSI at any rpm, while doing spirited runs through the mountains. OEM pressure is 54-62psi @ 3k rpms.
I was thinking about using a WIX racing filter for my next races. 28gpm flow.
