My 87 F250 has a Sterling rear axle and a Warner T19 manual transmission.
I want to change the oil in these.
The owners manual does not have weights. The local Chevron lube supplier, Napa, Oriley and the Ford dealer can't tell me what to use.
THe spec for the trans is "Standard transmision lube" #D8DZ-19C547-A Ford spec #ESP-M2C83C.
The rear axle needs EOAZ-19580-A OR ESP-M2C154-A
There are no other specs in the book.
BTW it has a Detroit Locker in the rear and Detroit says no ynthetic oil with their lockers.
Help!!!!
Help!!!!
