Auto-RX compatibilty with head gaskets?
Michigan
I am contemplating on using AutoRX, but have one small worry. The car I plan to use this additive in seeps a little oil past the head gasket and I am wondering if there is any chance the cleaning effect may worsen the insignificant leak. I'm pretty sure it won't hurt anything but I just wanted to put this in the air to see if anyone has any input on this. Thanks.....
Auto-Rx will (condition gasket material if not torn or ripped ) you have seepage because of contaminants hardened under gasket. Use Dino Oil with Auto-Rx and follow same application instructions for Auto-Rx to stop rear main seal leak. After cleaning your engine and stopping seepage from head gasket you can use any oil of your choice.
