Can Lube Control and Auto-RX be used together?
wtd
southwest Mo.
Can these two products be used together at the same time or should you just use one or the other?
Wayne
Each product cleans by a different mechanism.
I would use one or the other but not both at the same time; i.e., let each product do its own thing.
[ April 03, 2003, 11:10 PM: Message edited by: MolaKule ]
When I bought my LC & FP from Odis, I mentioned that I had a maint. dose of Auto-Rx in my oil. He wasn't really familiar with A-Rx, but said he would not recommend mixing them. Until I see recommendations from someone I trust(backed up by a documented test) that it's OK to mix them, I would *NOT* use my car as the guinea pig.I have FP, Auto-Rx, LC, & Neutra #131 in my carport closet. What do you mean, overboard?
I guess I will use the rest of my Auto-RX as maintenance doses and than start using the LC. I will do analysis on both to see which seems to give the best results. When I was ordering Fuel Power, Odis convinced me to buy the LC as well so I have a gallon of it to use. Thanks for the replies.
Wayne
I'm only short the RX,and I can't think of any more excuses to tell my wife as to why I need another "suplement" for the vehicles.No wait!! I forgot to get the RX for the tractors
I believe "simultaneously" and "together at the same time" are quite redundant, possibly to the 3rd power...
We don't need an oily excuse: we need an ALIBI !!!!
And "overboard" usually means at the very LEAST "across the rail"... Avast!
