It takes too long to get it started draining. The MityVac cannot be lower than bleed screw since the air bubble raise faster than the brake fluid comes out. If the MityVac is placed on top of the fender, then it does not have enough suction to pull the brake fluid up.
By the time I get it draining right, I could have done all four by hand.
