nomochevys
Thread starter
Originally Posted By: FNFAL308
Originally Posted By: kasedian
[censored] dude! Chill the [censored] out! If you're that [censored], throw it in the dumpster, and go buy a Homelite!
LOL, he will probably be able to find a Homelite in the dumpster. Homelite is NOT what it used to be!
LOL, now that's FUNNY!!
The Homelite stuff even now has a name but the Rep is LONG gone.. There was a time they made quality stuff but those days are ancient history..
To the OP~
These units are "usually" very good and not prone to any specific maladays.. As mentioned I "suspect" your problem is fuel related.. I am of course assuming that you have tried to standard/correct STIHL starting procedure..
660mag mentioned checking the Spark Arrestor screen and without seing the unit I would second that.. I had a BG55 just he other day in for a "NO START" Complaint and found the Spk Arrestor screen pretty much 100% blocked. In this case I suspect it was a combo of improper fuel mix ratio and LOW speed running partly becuase the customer was running the unit W/OUT the correct length tube.
I cleaned the screen, made a minor carb adj and the unit now starts and runs perfectly..
FWIW, I personally own/use a BG85, I've had it for a few years and have found it to be an excellent unit. Like I mentioned above these blowers are very good and don't really have any "issues"..
This blower has not had three tanks run through it as mentioned above. I have three other two cycles that run perfectly on the same gas. Two stihls and a shindiawa weed wacker. FWIW, the Shihndiawa is the best starting and running of the bunch.
WE just got a lemon. Im going to take it to my simplicity guy who sells stihl and gives excellent service. I think I have a dealer problem more than anything. So frustrating and has left a sour taste in my mouth. I will let you know what they find.
AS far as homelite, my Dad had one that lasted almost 20 years with no issues. They may not be any good now a days but he got a good one.
This blower has just sit around because we got so frustrated with it and went out and bought a Shindiawa. It starts and runs great. I believe they are a cut above Stihl even though I have had good luck with the older one. I have drained the gas and repeatedly tried to get it to run. I wonder if the newer ones have different carbs due to epa stuff?
To the OP~
