Originally Posted By: SOHCman
Thanks for all the replies, I have heard of people running with leaner oil ratios in their 'boys, but weren't there certain engines that needed the 32:1 specifically due to the type of bearings used?
I have a duraforce 6.5 model, so this probably does not apply? Which kind needed the 32:1? the bricks? the 80's models??
I have read that engines with bushings need more oil than engines with roller bearings, it make sense to me but I have no personal experience with that issue.
That sounds correct, it was something to that tune. The older lawnboys must have been bushing engines that couldn't survive with less oil...
Really a bushing? That would be a really [censored] bearing. There are needle, ball and roller bearing, never heard of a bushing in an OPE engine, but never had a Lawnboy. If they have bushings, then I never will.
