I just picked up an 03 330XI and from the maintenance records it looks like all the oil changes were done at the BMW dealer with the BMW HP 5W-30 synthetic oil right at pretty much the 10K to 12K interval. Although for the first 20K the oil was changed every 5K, then every 10-12K after that.
Car now has about 115k, and I was wondering if there is way to tell if there is a sludge problem in the engine, since I have read that a lot of people who have used the BMW HP Synthetic have had mild to severe sludge problems with that oil when run at the recomended BMW oil change intervals.
I did look under the oil cap by the way, and it looks very clean, almost new like, which made me wonder if the oil cap was changed at some point in the recent past.
I'm not looking to change the valve cover gasket or open the engine, just was wondering if there's any other way to identify a sludge problem in your engine.
Also if there is sludge problem present is the Mobil-1 0W-40 the oil with the most amount of detergents in it's add pack between the oils that are recomended/certified for this car.
thanks.
thanks.
