Originally Posted By: Ndx
I'm not in US, And the one close to Border dosen't carry it
10$ a Liter its a bit step ... for that car ... 60K Km on it ... but still ..
Thx
I expect with the car being almost 9 years old that the OP is not under warranty and the specified oil is almost impossible to acquire were he/she living correct? If this is the case a 15W40 HDEO is what I recommend.
15W-40
Viscosity, ASTM D 445
cSt @ 40ºC 114
cSt @ 100ºC 15.0
CCS, cP, ASTM D 6500 @ -20ºC
MRV, cP, ASTM D 19,000 @ -25ºC
HTHS @ 150ºC, cP, ASTM D4683 4.3
Viscosity Index, ASTM D 2270 137
Sulfated Ash, wt%, ASTM D 874 1.0
Total Base #, mg KOH/g, ASTM D 10.5
Pour Point, ºC, ASTM D 97 -30
Flash Point, ºC, ASTM D 92 236
Density @ 15ºC kg/l, ASTM D 0.876
0W-40
Viscosity, cSt (ASTM D445)
@ 40º C 75
@ 100º C 13.5
Viscosity Index 185
MRV at -40ºC, cP 31,000
HTHS Viscosity, mPa•s @ 150ºC, (ASTM D4683) 3.8
Total Base Number (ASTM D2896) 11.8
Sulfated Ash, wt% (ASTM D874) 1.3
Phosphorous, wt% (ASTM D4981) 0.1
Flash Point, ºC (ASTM D92) 230
So in short a 15W-40 will provide the target HTHS viscosity it will be a bit thicker at operating temps and thicker at start up so I would not flog the motor at startup. VI is not great in the favor of the HDEO but I assume it is warm were the OP is living you will not see very many starts with Frost/Ice on the ground? If so 15W-40 HDEO would be what I recommend in this situation, I do not always recommend something like this but you have to use what is available and reasonable. If a 10W-30 HDEO is readily available that would be something I would recommend over the 15W-40 if you do not treat your crossfire to a couple of simulated autobahn runs daily. Just do not start the engine then act like you are John Force and you should be fine.
To the posters that state that the OP should just use the recommended oil that recommendation is under the assumption that the recommended oil can be bought at the local dealer or local auto parts store. Normally I agree but sometimes circumstances dictate that the course of action can not be reasonably met and a suitable alternative must be found.
