I have a 454/640hp pump gas motor that I drive on the street, race occasionally. This latest version of the engine has been together now for about 10 years.
I always ran VR1 Valvoline 20W-50 racing oil in it. Liked the extra viscosity as I was always worried about break down or shearing (4.10 gear and no overdrive) so I buzz this thing down the road at 3500 for long periods of time.
I changed the oil last year with Valvoline Synpower full synthetic 10w-30 because I had some extra at the time and thought I'd give it a shot. A couple things happened.
1) Oil pressure dropped about 10 psi accross the board. Nothing scarey, still 25-30 psi hot at idle after a long high rpm drive, and it holds 60-70 while cruising.
2) My idle actually jumped up about 200-300 rpms. Guess the thinner oil is allowing the engine to spin more freely, probably freed up a few ponies, and I don't mind that.
This is a roller motor so no worries of flat cam lobes. It's time to change the oil again and I'm curious if I should stay with this synthetic, another synthetic, different viscosity, or stick the VR1 racing back in?
Maybe switch to the new Amsoil hotrod oil, possibly go with a 15w-40 mix? Anyone have thoughts on this?
