My Mom's 2009 Ford Fusion has 27k on it and the brakes vibrate.
Varies with pedal pressure from just a noise at light braking to sounding/feeling like driving over rumble strips at moderate pedal and gets worse from there.
I made an example video:
Does not show it as well as I was hoping it would, but you can still hear it.
Once I took it out to burnish the pads in, and it did get better but never totally went away. Then I accidentally got too aggressive so ABS intervened and it was right back where I started.
Think a pad slap and a good run-in will fix it? Or should I get the rotors shaved too? Im thinking it will be worth it to get rid of the vibration.
