Out of curiosity who sells the delvac 1? very hard to order it seems even over the net.. Could you have meant Delvac 5w-40 ESP?
http://paceperformance.com/i-6143260-mob...l-1-gallon.html like that... I can find that but not 5w30
about the above:
from mobil site:
Mobil Delvac 1 ESP 5W-40
Supreme Performance Heavy Duty Diesel Engine Oil
Product Description
Mobil Delvac 1 ESP 5W-40 is a fully synthetic supreme performance heavy duty diesel engine oil that helps extend engine life while providing long drain capability and potential fuel economy for modern diesel engines operating in severe applications. Mobil Delvac 1 ESP utilizes state-of-the-art technology to deliver exceptional performance in modern low emission engines, including those with Exhaust Gas Recirculation (EGR) and Aftertreatment systems with Diesel Particulate Filters (DPF’s) and Diesel Oxidation Catalysts (DOC’s), as well as refrigerated units and older, well-maintained engines. Mobil Delvac 1 ESP 5W-40 is recommended for use in a wide range of heavy-duty applications and operating environments found in the on-road transport and off-road mining, construction, and agricultural industries. Mobil Delvac 1 ESP also meets the requirements of the API SM specification for gasoline engines used in mixed fleets.
The outstanding performance of Mobil Delvac 1 ESP 5W-40 is the result of extensive cooperative development work with major equipment builders and application of the latest lubrication technology. As a result, this product meets or exceeds the requirements of the latest API, ACEA, and Global industry specifications for diesel engine oils, as well as the requirements of virtually all major American, and European engine manufacturers.
Features and Benefits
Many modern, low emission diesel engines generate more soot and operate at higher temperatures than older engines. This significantly increases the need for supreme performance lubricants. In addition, new engines (model-year 2007 and beyond) come equipped with aftertreatment devices installed in the engine exhaust stream which will require the use of both API CJ-4 oils and ultra-low sulfur fuels to function properly. Further, new engines using EGR will generate even higher levels of acid, soot and heat than older EGR engines due to substantially increased EGR rates compared to previous EGR designs. Top piston rings are located higher, bringing the oil film closer to the combustion chamber and exposing the lubricant to severe thermal stresses. Mobil Delvac 1 ESP 5W-40 maintains outstanding performance at significantly higher temperatures than other high performance diesel engine oils. It is also fully compatible with conventional oils. The key benefits include: Features Advantages and Potential Benefits
Meets or exceeds demanding specifications of major OEMs One engine oil for mixed fleet operations
Outstanding thermal and oxidation stability Reduced low temperature sludge build-up and high temperature deposits
Enhanced film strength at high temperatures Reduced engine scuffing and bore polishing
Inherent stay-in-grade shear stability Wear protection and reduced oil consumption; maintains viscosity in severe, high temperature service
Advanced formulation and viscometrics Improved fuel economy
Low volatility Reduced oil consumption
Exceptional low temperature pumpability Easy engine start-up and reduced wear
Enhanced TBN quality reserve Deposit control and extended drain capability
Outstanding resistance to corrosion Extended life of critical wear surfaces
Long drain capability Increased operating efficiency and lower overall cost
Component compatibility Long gasket and seal life, extended service intervals
Applications
Mobil Delvac 1 ESP 5W-40 is recommended for use in all super high performance diesel applications, including modern low emission engine designs with Exhaust Gas Recirculation (EGR), Aftertreatment systems with Diesel Particulate Filters (DPF’s) and Diesel Oxidation Catalysts (DOC’s). These applications include the following:
On-highway engines operating in both high speed/high load and stop-and-go conditions
Off-highway engines operating in severe low speed/heavy load conditions
Virtually all diesel powered equipment from American and European equipment builders
High performance gasoline engines and mixed fleets
Refrigeration units
Specifications and Approvals
Mobil Delvac 1 ESP meets or exceeds the requirements of: 5W-40
API CJ-4/CI-4 PLUS/CI-4/CH-4/SM/SL X
ACEA E7, E9 X
Caterpillar ECF-3 X
Cummins CES 20081 X
Twin Disc S364A X
Mobil Delvac 1 ESP has the following builder approvals: 5W-40
Detroit Diesel Power Guard Oil Specification 93K218, 93K214 X
Mack EO-O Premium Plus, EO-N Premium Plus 03 X
MAN M3277 X
MB-Approval 228.31, 228.3 X
Volvo VDS-4, VDS-3, VDS-2 X
Deutz DQC III-05 X
Typical Properties
SAE Grade 5W-40
Viscosity, ASTM D 445
cSt @ 40ºC 98
cSt @ 100ºC 14.7
Viscosity Index, ASTM D 2270 156
Sulfated Ash, wt%, ASTM D 874 1.0
Total Base #, mg KOH/g, ASTM D 2896 10.1
Pour Point, ºC, ASTM D 97 -48
Flash Point, ºC, ASTM D 92 249
Density @ 15ºC kg/l, ASTM D 4052 0.85
