Originally Posted By: hatt
I can't think of anything gas a farmer would use that isn't an ATV or some piece of equipment powered by a Honda, etc. Unless large numbers of farmers are using vintage equipment.
You'd be surprised. There is a lot of vintage equipment in use, just not for the "heavy lifting," necessarily. The big tractors, combines, and so forth will be newer and will have zero problems with ethanol, or, more likely, will run on diesel.
The issues that come to mind would be the smaller tractors used for snowblowing or pushing snow, moving bales, and that kind of thing. They very well could be much older and go through a lot less fuel.
On the other side of the coin, it's easy to blame ethanol for problems, while ignoring the fact that the fuel lines are original equipment from the 1940s.
