I only have a couple hundred of miles on the oil...will do an uoa when I accumulate around 5k miles. I might be pulling s*&t outta my butt, but I think my motor will wear nicely.
Quoting a fellow forum member on m3post.com, who also switched to a lighter oil.
"That's normal. I have seen 270F from time to time, as soon as it's not in limp mode, it should be fine. Just change fluid after that.
I had used Motul V300 10w40 for 8 hours track time in Infineon, Buttonwillow and LVMS, the highest temp was around 270F, plus 5k miles on normal driving. The oil analysis from Blackstone Lab said the oil was still in good condition, the wear metals looked very good on S65 engine, and they recommended I can use for a couple of thousands miles more for next oil change. But still, oil is cheap, I prefer changing it sooner."
Of course M1 0W40 ain't no Motul 300V, but this tells me weight probably won't be the issue, just the quality of the blend.
