Anyone run the longer version filter on their S10 2.2L? It's a 2001 S10 with the 2.2L. The filter is PF47 (AC Delco) which is about 3.5 inches long. There is a long version listed at the Baldwin filters site (B35-S vs spec B43-S), that is about 5 inches long.
The filter sticks off the side of the engine over the frame cross member. Plent of room for the added length and would make it easier to remove, but it looks like the dome end would be pretty close to the frame cross member, which is not a problem but for how much the engine wiggles in the mount. Of course if you blow an engine mount it could be a disaster.
Suppose I could put the longer filter on and see the space, rev it good a few times and see if it hits.
