In my 1995 Ford Ranger I replaced the manual transmission fluid at 43,600 miles with Castrol Dex/Merc. I am currently at 70,700 miles.
I chose this fluid because the manual calls for Mercon lubricant. However with only 27k miles on the fluid the shifting seems really notchy to me. Would I be better off switching to something like Redline's MTF and ditching the ATF that Ford recommends? If so, is there anything similar to Redline MTF I can use so I'm not using such an expensive fluid in a simple tiny truck from 1995. It's not like I'm not doing much hauling with it, the thing has a 2.3L and can barely get out of its own way.
