Originally Posted By: NattyBoh
Im still trying to find information on which chemicals can be used to clean the innards of the injector... There is literally nothing on the net explaining what can and cant be used. [censored] nothing even on HOW to do it. But I thought, why not check here? So any help??
I have heard, and read in the operations manuals, that you are not suppose to use flammable liquids in an ultrasonic cleaner, but I worked at a place that had been using acetone in Ultrasonic cleaners for about 20 years with no explosions. When I had one, I used Dawn or Ajax dish soap with hot water. I sometimes used flammable liquids in a separate container sitting in the water. My U-S tank was large and filling it with solvent was expensive. I would put small parts into a glass jar with the solvent, then put the jar in the U-S cleaner. It worked fairly well. They make special cleaning fluid; some of it contains acids. If I left brass parts in too long they would turn pink because the zinc was being removed from the surface leaving just copper.
