Originally Posted By: Char Baby
Garlicbreadman,
My wifes '01 Lexus RX-300(similar in many ways to your Sienna) was doing this at about it's 8-9 year mark although a little differently than the yours.
After restarting the engine, the digital clock on the indash screen would reset to 1:00(not 12:00 as one would think). And too, the brightness for that screen would be several bars lower in brightness causing me to > up the brightness to my original liking/setting.
IMHO, these are built in designs/signs that the battery is on it's way out. Even though my battery still had enough power to restart the engine even in the cold winter, these are still signs that one or two of the battery's cells are not at optimum. Maybe even reading < 12 V with the engine off.
IMHO...it's the battery! Even if the battery is strong, maybe it's corrosion or a weak connection on one/both of the +/- posts.
And too, your right about where we were in terms of years old the battery is/was when you noticed the issue. These Toyota/Pannisonic batteries are strong and long lasting but, I think it's time for a replacement.
Good luck and keep us posted.
CB
BINGO! I had always suspected the battery was the problem and it is! New group 35 kirkland battery in the sienna and the radio is working perfectly! Odd, this car originally had a 24f group battery i believe..
