http://www.noln.net/columns/1-05/chevrontexacojan05.html
Should be noted that the oil started at a TBN of 6, so probably the cheapest XW-30 Havoline Dino was involved here. The article also doesn't provide really any evidence that a drain interval of 12k miles with ChevronTexaco's oil isn't appropriate, and I feel it is fairly weak in impugning that a 3000 mile oil change is necessary. Interesting, eh, even some of the industry propoganda is getting fairly weak.quote:
A good rule-of-thumb for determining engine oil life is to look at the point where the acid and base number curves cross. In my case, the crossover point in Figure 2 occurs at about 3,000 miles. (Gee…maybe there is some science behind the recommended drain interval of 3,000 miles!)
