Originally Posted By: 1 FMF
75,000 miles on factory fill GM purple smelling gear lube.
What year and what type vehicle? It looks like a 14 bolt, so I am guessing it is a heavy duty truck.
There was a blue colored 75w-90 in my 2001 GMC truck.
As others have said, it looks like water contamination.
Did you buy the truck from someone who had a boat?
People who have boats on a trailer usually put the rear axle under water when they back their trailer into the water. One of the most common mistakes is to back into the water immediately after a long drive. What happens is the rear end gets warm/hot and the air inside expands. When the put the hot axle in the water it almost instantly cools down and pulls water in through the axle seals and axle vent. The seals are meant to keep the fluid inside the axle, and not really to keep something out. Your brake calipers/cylinders would do the same thing if you put the caliper under water before letting it cool down. Since your rear end looks like it was contaminated with water, I suggest you flush your brake system also, just in case the previous owner had a boat. It wouldn't hurt to do it anyways. If you have a 4 wheel drive, check the front differential as well. 75,000 is a good time to change it. I do mine between 30,000 and 50,000 miles.
